Activity Forums Maxon Cinema 4D mapping an image to the side of an extruded rectangle path
  • mapping an image to the side of an extruded rectangle path
    Posted by Jacques Levet on June 21, 2011 at 5:14 pm
    Good morning.
    I m running into some trouble while trying to map a picture to the side of a extruded rectangle path.
    I built a grid in illustrator and brought the path in C$D and extruded them. I mapped pictures to the front of the rectangles without any problems. Now i want to map a different pict to the sides, but i m not figuring out how it can be done. I tried to make the extruded nurb editable, but i m not able to select the side with the polygon tool. ANy idea on how i can map a different image to the side of the rectangle?
    Any help or suggestions would be greatly appreciated
    Sincerely
    J.
    Phil Dec replied 15 years, 2 months ago 2 Members · 1 Reply
  • Phil Dec
    June 24, 2011 at 2:03 pm
    Hello,
    I think you should not make your extrude nurb editable.
    Instead, right-click on it in the objects browser and select “Current state to object”.
    Then you should be abble to switch into polygon mode and select each side individually.
