Activity Forums Maxon Cinema 4D mapping a png to a disc…
  • mapping a png to a disc…
    Posted by Justin Rank on January 1, 2007 at 7:06 pm
    I’ve created a disc and mapped a png with alpha onto the disc but I’m getting a white halo all the way around the image almost like the map isn’t big enough for the disc. The png is 2000×2000 so I don’t think it’s a size problem.
    Since both the disc and png are perfect circles, how can I get rid of the white halo?
    Justin Rank replied 19 years, 8 months ago 2 Members · 2 Replies
  • Mylenium
    January 1, 2007 at 7:15 pm
    Turn of texture filtering (will require you to crank antialiasing way up, so it may not be that sensible) or adjust your texture. Either make it slightly larger or fill the surrounding pixels with the same color as your current edges. This is called dilation and is a common requirement to hide texture seams.
    Mylenium
    [Pour Myl
  • Justin Rank
    January 1, 2007 at 8:20 pm
    I adjusted the x and y sizes and it worked fine. Thanks again for the help. 😎
