Activity › Forums › Avid Media Composer › Mapping a menu function to keyboard
  • Mapping a menu function to keyboard
    Posted by Peter Groom on December 31, 2008 at 10:44 am
    HI everyone
    Id really like to map the meny function “render in to out” to the keyboard.
    Can anyone explain where im going wrong
    open keyboard
    select map foreign
    click the key where i want it to go to (stays purple)
    go to menu drop down
    but its dimmed out so i cant select it!!!
    Where am i going wrong
    Cheers
    Peter
    Ian Johnson replied 17 years, 9 months ago 3 Members · 3 Replies
  • Jon Zanone
    December 31, 2008 at 1:33 pm
    Do you have a foreign keyboard? If not, don’t select it. Select the ‘button to menu’ radio button. Click the key on your keyboard. The cursor should turn into a little square. Go to the menu item you want to map – click on it. You are done. If you want to map items from the command pallette (cntrl + 3, or tools>command pallette) select the ‘button to button’ button (who’s got the button…)
    Jon
    “Jamming our heads full of figures and angles
    And telling us stuff that we already know”
    Willie The Wandering Gypsy & Me
    Billy Joe Shaver
  • Peter Groom
    January 1, 2009 at 1:14 pm
    Thanks Jon
    Sorted
    Peter
    Have a good New Year
  • Ian Johnson
    January 1, 2009 at 7:17 pm
    Some menu items are context sensitive, so you have to set up the conditions before you can map it. In this case, you need a sequence in the timeline with In and Out points set to make Render In-Out selectable for mapping. There are some others like this, such as Load Filler which needs the source monitor to be the current active window before you can map it.
    Ian
