Activity Forums Adobe After Effects Mapping 2-D Objects in 3-D Cinema Files
  • Mapping 2-D Objects in 3-D Cinema Files
    Posted by Luis Salcedo on April 23, 2010 at 10:39 pm
    Hey guys,
    I am trying figure out what is the best way to map 2-D moving objects on 3-D objects.
    I am thinking I cant just go and add a movie clip in an object’s surface in Cinema 4D, but I think in after effects there a way to add to a moving object a looping texture.
    I know I can set null objects in Cinema 4-D so I can then place objects in the desirable z-space in AE, but that doesn’t take me too far this time.
    Here is an example of the technique I am trying to achieve:
    https://vimeo.com/9506884
    Thanks everyone. Your advices are very much appreciated.
    -Luis
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Erik Waluska replied 16 years, 4 months ago 2 Members · 1 Reply
  • Erik Waluska
    April 24, 2010 at 2:55 pm
    You’ll probably have better luck if you post in the Cinema 4D forum.
