Activity Forums VEGAS Pro Map with moving route line
  • Map with moving route line
    Posted by Steve Edwards on July 7, 2005 at 4:02 am
    I’m wanting to create a map with a moving line showing a route of travel. I have begun going the route of putting a map on one track, making a copy of it and placing it on the track above the first one. Using the cookie cutter filter, but then get stuck there
    Peter Wright replied 21 years, 1 month ago 4 Members · 5 Replies
  • Gary Kleiner
    July 7, 2005 at 4:16 am
    Instead of cookie cutter, animate a bezier mask. Easiest way is simply to do a wipe transition between the two versions.
    Gary Kleiner
    Vegas Training and Tools.com
  • Steve Edwards
    July 7, 2005 at 4:20 am
    Don’t know how. And the other way, do you scan a pic of a map, then take that copy and draw on it and scan it again?
  • Strobealific
    July 7, 2005 at 6:16 am
    That would probably work too…with a LONG wipe in between the two.
    Marc Bowyer
    StrobeAlific Media
  • Gary Kleiner
    July 7, 2005 at 6:37 am
    You would scan your map, then add the line to the graphic file in a paint program. That way, they are exactly the same except for the line.
    Gary Kleiner
  • Peter Wright
    July 7, 2005 at 7:45 am
    … and, with Vegas’s Transition Envelope you can change the speed at which the line is revealed or even pause it whilst you describe a pause in your trip.
    Peter Wright
    Perth, Western Oz
    http://www.allroundvision.com.au
