Activity Forums Boris FX Many entries in RED Keyframe Library have errors
  • Many entries in RED Keyframe Library have errors
    Posted by Peter Honig on June 11, 2009 at 1:31 pm
    After updating yesterday to Red 4.3.3 I happened to take a very close look at the entries in the Keyframe Library (I had built the project previews in November 2006 when I originally bought Red 4.0). I am now surprised to see how many projects do not work correctly. The most problematic ones are those that use the obsolete filters: “2D Particles Advanced” and “Luma Pixel Noise”. I don’t recall at what point these two filters disappeared, but I definitely do not have them.
    The most problematic areas of the Keyframe Library are “Filters->Noise”, and “Filters->Particles”. However, there are a quite a few entries in other areas that also do not work correctly. Though I build most of my composites from scratch, occasionally I use an entry from the keyframe library as a starting point. My question to BorisFX is are there any plans to repair the entries and eliminate the references to obsolete filters?
    Peter
    Peter Mcauley replied 17 years, 3 months ago 2 Members · 3 Replies
  • Peter Mcauley
    June 11, 2009 at 1:58 pm
    Hi Peter,
    Thanks for bringing this to my attention – I’ll move this forward to engineering to see what they can do to resolve the issue of the broken templates.
    Cheers,
    Peter.
  • Peter Honig
    June 12, 2009 at 3:57 pm
    Hi Peter,
    I have already repaired quite a few templates, including those that still worked but refered to obsolete versions of existing filters. My goal has been to elimate all references to “(Obs.)” filters. I would be very happy to share these with you if you wish.
    Regards,
    Peter
  • Peter Mcauley
    June 12, 2009 at 7:43 pm
    Hi Peter,
    Could you please send me an email off list? You can reach me at peterm@borisfx.com.
    Cheers,
    Peter.
