Activity Forums Adobe Photoshop many Brush elements are not 100% transparent
  • Brendon Murphy
    October 15, 2020 at 10:57 pm
    Are you using a wacom pen with pressure sensitivity? If so, you may need to hold longer for the brush shape to be 100% transparent. One way to test this is to try using a mouse instead – is it 100% transparent?
    If nothing else works, you could always use a levels adjustment on your mask after you are done painting the stars (alt-click the mask to edit it). Squeeze the Input black Point in a tiny bit so the brush strokes become fully black.
