Activity › Forums › Adobe After Effects › Manually install codecs?
  • Manually install codecs?
    Posted by Sagar Sangani on July 13, 2010 at 10:41 pm
    So I installed the trial version of AE CS5 and apparently MPEG rendering is not offered in trial version. So I was wondering if there a way to install these codecs manually since I have a project that needs to be rushed?
    MPEG rendering does work, however, it takes extremely long to render and I found the trial version was a problem. Do you think simply downloading an MPEG codec and installing it on the system would work?
    Sagar.
    Sagar Sangani replied 16 years, 2 months ago 60,577 Members · 2 Replies
  • Sagar Sangani
    July 14, 2010 at 2:03 am
    Thanks, Dave.
    Maybe I should have been a little clear about my project. You see, I am trying to render an animated motion menu which is in AE. All the other videos that I edit in Premiere Pro are exported with Media Encoder.
    The reason why I select MPEG is because all the HDV files are in mpeg format and I think it would be better to be consistent throughout the project. I’ve exported in AVI better using Media Encoder and it has been very quick on CS5 64bit Win7.
    I am have previously tried to render in MOV and it has taken a significant amount of time.
  • Sagar Sangani
    July 14, 2010 at 9:44 pm
    Wow, really? Thanks for the info.
    I’ll stick to QuickTime format.
