Activity › Forums › Maxon Cinema 4D › Manual Joint binding problems
  • Manual Joint binding problems
    Posted by Brad Douglass on May 3, 2012 at 4:08 pm
    I have a simple project in C4D 13 where I’m trying to make a bending straw with 1 simple joint chain. And I can’t figure out how to bind the joints to the mesh. I think I’ve done all the correct steps (weight tag with all joints referenced as well as a skin element attached to the straw object) but nothing seems to actually attach the joints to the object so it can deform. Does anyone have any suggestions? Thanks in advance.
    -Brad
    Here is the link to the file:
    https://f1.creativecow.net/4076/4076?uploaded=file
    Alfonso Montalvo replied 10 years, 9 months ago 3 Members · 2 Replies
  • Brian Jones
    May 4, 2012 at 1:58 am
    delete the skin object and the Weight Expression tag
    — optional—-
    take the Root object (and the joints) out from under the straw so they are not children anymore
    but it will work if you leave it alone – the joints can be anywhere
    Select all the joints (*not* the Root null) and the straw object and run the Character/Commands/Bind command, that should do it
  • Alfonso Montalvo
    December 27, 2015 at 1:36 am
    This worked for me!!, thanks a lot has been hours of frustration…….thanks thanks thanks!!!
