Activity › Forums › Adobe Premiere Pro › manual for SONY J-3
  • manual for SONY J-3
    Posted by Sebastian Toth on June 20, 2015 at 2:33 pm
    Someone have operation manual for compact player SONY J-3 (not J-30) I tried to google it. And without success. And one more question. SDI out on betacam is always interlaced upper field? I have AJA Io Express on windows 7. And use QT uncompress 422 10 bit signal.
    Mike Dziennik replied 11 years, 3 months ago 4 Members · 5 Replies
  • Chris Tomberlin
    June 20, 2015 at 7:51 pm
    I have a J3; I can look around monday for the manual. HOWEVER, since the J3 is a standard-definition deck, I can tell you that the output would but LOWER field first. HD is upper field first.
    Chris Tomberlin
    Color/Finishing
    Outpost Pictures
  • Mike Dziennik
    June 20, 2015 at 9:00 pm
    Depends on the frame rate:
    PAL (25fps) is UPPER field first.
    NTSC (29.97fps) is LOWER field first.
    HD (25fps) is UPPER field first.
    HD (29.97fps) is UPPER field first.
    Mike
  • Sebastian Toth
    June 22, 2015 at 9:01 am
    Thank you Chris,
    it would be very kind.
    Sebastian
  • Ann Bens
    June 22, 2015 at 9:09 am
    PAL is lower field for SD.
    Adobe Certified Expert Premiere Pro CS6/CC
    Adobe Community Professional
  • Mike Dziennik
    June 22, 2015 at 12:38 pm
    Only for the DV codec.
    Otherwise, PAL (SD) is Upper field first.
