Activity Forums Panasonic Cameras Manual Focus
  • Manual Focus
    Posted by Alex Kink on June 19, 2007 at 2:42 pm
    Hi there
    I just recently got myself a used DVX100. I found two problems with it. The first one was the 2nd speed for handle zoom, which turned out to be a setting. The second and more important problem is manual focus. If i put the switch into the manual setting, the focus wheel doesn’t work. The focus stays on what the last automatic setting was.
    I’m wondering if its another setting somewhere or is the wheel broken.
    Thanks in advance!
    -Alex
    Joe Gill replied 19 years ago 3 Members · 2 Replies
  • Lance The tech
    June 20, 2007 at 6:15 am
    There is no way you can actually stop the manual focus from working, when you switch the switch to manual. So if it doesn’t work chances are very good the optical sensor that sees the manual focus ring turning is broken. This is not a very expensive repair, and very easy to do. You would need to have the “manual focus unit” replaced.
  • Joe Gill
    September 22, 2007 at 12:18 am
    Whats a good place in LA to get my unit reparired – I have the same issue…
    thx
