Activity Forums Audio manual audio settings/ex1r
  • manual audio settings/ex1r
    Posted by Jim Stamos on April 25, 2012 at 8:43 pm
    going to put an AT897 on my ex1r. since ihavent using the manual audio settings much, would love some input from you experts.
    mainly concerned for loud music at receptions. it was suggested by a guy at nab that i use the AT897 on the manual settings and take the trim off the default 41db and set it to 35db and adjust the manual control as im monitoring the meters.he said that i shouldnt get the hot overmodulated audio ive gotten b4 when i had the cam set on agc. comments welcome.
    also do i adjust anything with the gain setting in the audio menu??
    thanks for your responses.next wedding is in june.
    Andrew Rendell replied 14 years, 4 months ago 3 Members · 2 Replies
  • Richard Crowley
    April 26, 2012 at 12:05 am
    Note that the AT897 will handle a significantly higher SPL using phantom power vs. using the internal battery. So first of all, ditch the battery and use real P48 to power the mic.
    If you don’t have a manual for your EX1R, I very strongly suggest that you download one and start studying it. The complete instructions for adjusting the audio gain trim are found in the manual. Take some time to familiarize yourself with this and other common menu settings so you don’t waste time on location fiddling with your camera.
    If the SPL is all that high, why even use a shotgun mic? I would try simply using the built-in cardioid pair.
  • Andrew Rendell
    May 2, 2012 at 9:07 am
    I agree with Richard, go through the manual and DO SOME TESTS as well. IMO the limiters in the EX1 will save you from clipping, but they’re too intrusive for my taste, so I’d record at levels a few dB lower than normal on those cameras to avoid them kicking in too much.
