Activity Forums Adobe After Effects Manipulating and animating individual points
  • Manipulating and animating individual points
    Posted by Keith Vickers on October 24, 2013 at 10:39 am
    Hi guys, I have a 8 pointed star. I want to revolve the star, scale it and have 4 points grow outward while the remaining points stay where they are.
    Basically I want to know how to manipulate and animate single points on a bezier path. Is this possible?
    I have already tried the Puppet tool(fantastic) but it does not give me the results I need.
    Can any wise member help out a newbie?
    Edit: I got the effect I wanted by scaling the stars Inner and Outer points in the shape layer’s attributes for Inner and Outer points of the star.
    I could still do with some hints on how how to animate single points.
    Keith Vickers replied 12 years, 10 months ago 4 Members · 4 Replies
  • Kevin Camp
    October 24, 2013 at 5:54 pm
    if you make your star as a mask on a solid rather than a shape layer, you can manipulate the individual points, however you’ll lose the shape properties (like inner and outer radius).
    just create a new solid, then (with that solid still selected) use the same star tool to create the star. since you have a layer selected, it will make a star shaped mask. you can then use the pointer tool to select a point and move it.
    to animate that, you’d twirl down the mask properties and keyframe the mask path.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Mathew Fuller
    October 25, 2013 at 5:34 pm
    To expand on what Kevin said.
    Keep in mind that the keyframes for masks always represent all the points on the mask. There is not a way to individually have a keyframe for each individual point on any given mask…
    At least not that I know of… and I’ve never had a need to.
    My Work:
    https://www.morecompletefx.com
  • Todd Kopriva
    October 25, 2013 at 10:43 pm
    There are some handy scripts that add this ability.
    Here’s one:
    https://aescripts.com/bao-mask-avenger
    … and some here:
    https://www.crgreen.com/aescripts/
    After Effects team blog
  • Keith Vickers
    October 29, 2013 at 4:29 pm
    Ok guys, thanks for the replies so there is no way of animating individual points on a shape.
    So if I have a star and I want the effect of one of the points stretching out over time and returning to its original position how would I do that?
