Activity Forums Adobe After Effects Expressions Manipulated first keyframe
  • Manipulated first keyframe
    Posted by Mathias Van sele on September 6, 2018 at 8:11 am
    Hey Guys
    I’m trying to make a Lower third. And let the editors change the text values in Premiere with Essential graphics.
    Now i need to change the X-position of the first keyframe of the text layer.
    At the moment i found following expresion:
    x2 = thisComp.layer(“Null 1”).effect(“Slider Control”)(“Slider”);
    x = linear(time,key(1).time,key(2).time,key(1).value[0],x2);
    [x,value[1]]
    It works but only for the second keyframe. How can i change it to the first keyframe?
    Thanks alot.
    x2 = thisComp.layer("Null 1").effect("Slider Control")("Slider");
    [x,value[1]]
    Andreas Brand replied 8 years ago 2 Members · 1 Reply
  • Andreas Brand
    September 6, 2018 at 3:00 pm
    I hope I understand you right.
    You want to replace the x-value of the first keyframe with the value of the slider?
    If so, try this code, I hoope it helps:
    x1 = thisComp.layer("Null 1").effect("Slider Control")("Slider");
    x = linear(time,key(1).time,key(2).time, x1, key(2).value[0]);
    [x,value[1]]
