Activity › Forums › Maxon Cinema 4D › Manipulate multiple bump maps?
  • Manipulate multiple bump maps?
    Posted by Greg Neumayer on October 22, 2012 at 9:52 pm
    Hi there. I’m building a column, with 3 different bump maps: the surface texture, the fluting, and the horizontal division lines making it look like multiple chunks set on top of each other. I’ve got all 3 bump maps in a Layer shader, but I can’t figure out how to manipulate the position and scale of them independently of each other. Am I constrained to only using the overall texture tool, or can I adjust them independently to get the positioning I need?
    Greg
    Antifreeze Design
    https://www.antifreezedesign.com
    Brian Jones replied 13 years, 11 months ago 2 Members · 1 Reply
  • Brian Jones
    October 22, 2012 at 11:09 pm
    you could use Transform from the Layer Shader’s Effects menu (put each image/Transform pair into a Folder to keep the Tranforms from ‘adding’) or use 3 Projectors from the Layer’s Shader/Effects and put your images in those. More control in the Projector but simpler with the Transform if you don’t need to change the actual projection of the images.
