Activity Forums Adobe After Effects Managing multiple stills in AE
  • Managing multiple stills in AE
    Posted by Sean Grace on August 25, 2008 at 6:29 pm
    Can somebody suggest a good way to load and manage still photos for motion work in AE? I need to load 200 images, make them all the same dimension and create various montages. Is there a “batch load” function for all images to conform to a certain size? Any ideas in this department are greatly appreciated.
    Sean Grace
    Jerry Renes replied 18 years ago 2 Members · 3 Replies
  • Jerry Renes
    August 26, 2008 at 9:54 am
    Hi Sean,
    I think you should first think of what you want to do with the photos exactly. I mean, what is the biggest resolution you need? Etc.
    Then I personally find it convenient to do a resize batch in Photoshop. I suppose you know how to do a batch in Photoshop here. You could also use: File > Automation > Fit Image. There you can give Photoshop a certain width & height and will fit all images within these width & height values.
    Then you could just load all images in AE. Drag them into the compostion. You can copy the animation keyframes from one of the layers to the other ones. Or just select them all and place them in the right spot.
    You could if needed use the Keyframe Assistent to sequence all the layers. (Select all layers > Keyframe Assistant > Sequence Layers)
    Hope this info helps! Good Luck!
  • Sean Grace
    August 26, 2008 at 2:38 pm
    Thanks Jerry! The Photoshop route seems logical. My objective is to load 200 images which I can then arrange in various ways in AE (flowing rivers of images, spinning carousels of images, etc.) and then have them all assemble on a back wall as a montage. I was hoping there was a script I could use to launch these various animations.
  • Jerry Renes
    August 26, 2008 at 5:19 pm
    Maybe there is but can’t help you with that.
