Activity Forums VEGAS Pro Making Window Larger
  • Making Window Larger
    Posted by George Tsiripas on June 17, 2012 at 9:39 am
    Hi guys,
    A simple question here which is driving me nuts. I used to open as much every window I wanted in vegas. After a point don’t really remember what changes I simply can not maximize the window. It stays in that tiny area where I can barely see and edit anything.
    As you can see in the image, I am trying to open a bit the window but the text area is being still the same. Help! 🙁
    https://i1261.photobucket.com/albums/ii594/tsiripas/1-4.jpg
    Paul Beller replied 14 years, 2 months ago 5 Members · 6 Replies
  • Graham Bernard
    June 17, 2012 at 10:42 am
    [George tsiripas] “I used to open as much every window I wanted in vegas.”
    Yes, but not this one. And I think this IS the very type of window one would want to, too.
    Grazie
  • George Tsiripas
    June 17, 2012 at 4:51 pm
    You mean you can’t make it any bigger?
  • Mike Kujbida
    June 17, 2012 at 6:46 pm
    [George tsiripas] “You mean you can’t make it any bigger?”
    That’s correct.
  • Paul Beller
    June 18, 2012 at 9:10 am
    it is possible but you would have to hack sv, recompile exe or some of dlls, exchange bitmaps probably…
  • Nigel O’neill
    June 19, 2012 at 1:01 pm
    I would strongly recommend against doing that. The limitation George is experiencing is imposed by Sony/developer. Text titles are generally not meant to be verbose.
  • Paul Beller
    June 19, 2012 at 1:14 pm
    it is a game for experts and not worth of the result. do you really work so much with titles? is it really so uncomfortable? … well maybe a bit but hacking the system and a possibility of further problems in result is not worth of all that.
    i only mentioned a possibility but i don’t recommend it either.
    if you use photoshop, you can use it very efficiently for your titles in fuuuuuullllscreeeen 🙂
