Activity › Forums › Adobe After Effects Expressions › Making waves with path expressions
  • Making waves with path expressions
    Posted by Gergely Bencsik on August 15, 2021 at 3:08 pm
    Hi there!
    Not really a question, just sharing what I discovered recently, and had a lot of fun playing with it. Used it in my video here:
    https://youtu.be/CTllCx5pHvM
    In this expression I set up a bunch of points on a horizontal ‘X’ direction line, and created y values based on a slider ‘Lead’. The core of the trick is to delay the input value based on x. So you define a wave speed, and then divide your x coordinate with the speed to get the ‘time to get there’. Then animate the slider with keyframes however you wish, it will propagate it down the line.
    N=200;
    Length = 600;
    Wave_speed = 200;
    wave_points = [];
    for(i=0; i<N;i++)
    x = i/N * Length;
    wave_time = x/Wave_speed;
    // slider effect named ‘Lead’
    y = -effect(“Lead”)(1).valueAtTime(time-wave_time);
    wave_points[i] = [x,y];
    createPath(wave_points, [], [], false)
    Gergely Bencsik replied 5 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
