Activity Forums Apple Final Cut Pro Legacy making vector graphics look their best in fcp
  • making vector graphics look their best in fcp
    Posted by Sam Woolf on May 15, 2008 at 11:29 am
    Hi there,
    I have an adobe illustrator vector image I want to composite into my fcp movie – I can’t make it look nice – basically I’m converting it into a high res png and sticking on the top video track, but it always ends up looking pixelly. I have tried comping it in after effects and it looks fine – but I want to avoid having to do extra renders in after effects if possible as I have lots of files to do. Surely there must be a way to make it look equally good just using final cut pro?
    Many thanks,
    Sam.
    Chris Poisson replied 18 years, 4 months ago 3 Members · 2 Replies
  • David Roth weiss
    May 15, 2008 at 11:53 am
    If you’re working on a DV timeline that’s your problem. DV compression does not do good things to text and graphics.
    The solution is simple, change the Compressor under Sequence — Settings to DV50, or ProRes and rerender the timeline.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Chris Poisson
    May 15, 2008 at 2:13 pm
    David is correct, although when I do this I usually use 8 bit. I don’t like DV50.
    Have a wonderful day.
