Activity Forums VEGAS Pro Making transitions faster
  • Making transitions faster
    Posted by Karina Yefremova on November 12, 2014 at 1:29 am
    Hello! I just started using sony vegas, and I need assistance with how to make the transitions faster. For example i’m trying to do a push up transition between two clips however it’s too slow. Thank you!
    Karina Yefremova replied 11 years, 10 months ago 3 Members · 3 Replies
  • Mike Kujbida
    November 12, 2014 at 1:44 am
    The only way to make the transition go faster is to shorten the overlap time between the two events (what Vegas calls a clip).
  • Phil Peacock
    November 12, 2014 at 9:45 am
    As Mike said. Just drag with the left mouse button the left or right edges of the transition to shorten the duration of the transition.
  • Karina Yefremova
    November 12, 2014 at 7:07 pm
    Thank you very much!!! to both of you.
