Activity Forums Apple Final Cut Pro Legacy making timecode visible
  • making timecode visible
    Posted by Mark Wilkinson on October 12, 2005 at 11:04 pm
    ve got some long files that i need to post on the web and let a client pick some pieces out of. is there a way to lay timecode visibly over the movie so that they can use it as a reference ?
    Espnetboy3 replied 20 years, 11 months ago 3 Members · 5 Replies
  • Brian T
    October 12, 2005 at 11:16 pm
    There is a Timecode Generator filter in the ‘Video’ folder under the Effects tab. You may want to nest the sequence before you apply the filter.
  • Mark Wilkinson
    October 12, 2005 at 11:34 pm
    thanks ! nesting the clip would help in what way ? i thought maybe it would help me avoid rendering it but i just nested it and got the big red bar up top.
  • Brian T
    October 12, 2005 at 11:42 pm
    If there are several cuts in your sequence, the TCG filter will only apply to one clip and give a display for the duration of that one clip. If you nest your clips together, then apply the TCG filter, it will display from the first frame to the last frame of the entire sequence. Unfortunately, since the TCG is a filter, you will most likely have to render. Hope this helps.
  • Mark Wilkinson
    October 13, 2005 at 12:11 am
    ah..of course. thanks yes, that does help.
    ciao
    mark
  • Espnetboy3
    October 13, 2005 at 12:14 am
    In laymans terms can someone explain what how to nest and what is the benefit from doing this. Also pre composing? THanks
