Activity › Forums › Adobe After Effects › Making this countdown in expressions?
  • Bas V breugel
    June 4, 2012 at 9:00 am
    incase the mp4 doesn’t work, see https://www.loepzuiver.net/faq/countdown.html
  • John Cuevas
    June 4, 2012 at 11:50 am
    Here’s a pretty basic expression that should do what you need:
    // set end time to comp duration
    beginTime = 1;
    endTime = 10;
    counterStart = 269;
    counterEnd = 130;
    Math.floor(linear(time , beginTime, endTime, counterStart , counterEnd ))
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • John Cuevas
    June 5, 2012 at 1:01 am
    Just realized that I didn’t mention you would create a text layer(cntl+alt+shift+t), twirl down and add that expression to the source text.
    Thinkck.com
