Activity Forums Adobe After Effects Making the PERFECT Ring
  • Making the PERFECT Ring
    Posted by Marty Nowak on September 30, 2008 at 3:55 pm
    I am trying to do something that seems like it should easy but Im getting undesirable effects.
    I want to make a “perfect” circular ring. My approach was to create a new shape layer and draw the circle and then increase the stroke. Seems easy going in but here my problems:
    How do I constrain the drawing of the circle? Instead, Im getting an ellipse I try to make into a circle by eye.
    Also when I create the stroke, the inner part of my ring when I increase the stroke becomes a football shape. Im frsutrated. Please help.
    Kevin Camp replied 17 years, 11 months ago 4 Members · 4 Replies
  • Todd Perchert
    September 30, 2008 at 7:06 pm
    Try holding the Shift key when making your circle shape layer. That should constrain it to a circle.
    TC
  • Mark
    October 1, 2008 at 10:30 am
    Or use the elipse filter on a solid layer. The elipse will allow you to create a circle or elipse, and it has stoke built into the filter. A really nice looking effect.
    regards
    Mark
    Mark Harvey
    Senior Editor
    Le Réseau des sports
  • Marty Nowak
    October 1, 2008 at 3:34 pm
    OK, so here I am again. I think it might be some overall setting because my particles I created also seem to be elliptical. Im taking a tutorial and following it precisely but the only difference is my particles are elliptical.
    Any advice based on this new piece of info?
  • Kevin Camp
    October 1, 2008 at 5:33 pm
    are you working in a square pixel comp or a nonsquare pixel comp? and, are you viewing your elliptical particles on the computer display or a broadcast monitor?
    if you are working in a standard broadcast preset (like the ntsc dv preset) then you pixel aspect ratio is .9 (nonsquare). so, on a computer display, a circle will look a bit stretched out horizontally (elliptical). on a tv, that same ellipse will look like a circle.
    ae has a crude pixel aspect ratio correction button that toggle back and forth, so you can see your previews with a corrected aspect ratio (bottom of the preview window, towards the right side), but it may be easier to just work in a square pixel comp like the ntsc d1 square pixel preset…
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
