Activity › Forums › Adobe After Effects › Making Text take form of part of a wall (object)
Posted by Richie Soto on March 20, 2009 at 6:35 pmPeace…
I’ll to explain it the best that I can.
I am trying to have text (“productions”) come from behind a still I have and push thru to take form of the wall (object) — so the word “productions” is taking form of part of the wall and also readable.
Wondering if there is a tutorial for this?
Hope I was clear — I always have difficult explaining what I see in My head..haha.
Thanks..
RichieRichie Soto replied 17 years, 6 months ago 3 Members · 6 Replies -
Roland R. kahlenberg
March 20, 2009 at 8:03 pmTry Blending modes and even Texturize on the text.
HTH
RoRKbroadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available)
Jon Geddes
March 20, 2009 at 11:46 pmIf I understand correctly what you are trying to achieve, then it should actually be done in a 3D app to look just like you are imagining it. However, there are some techniques in after effects you can use to make it look somewhat like you want from the front view only.
You can create a black solid layer, type the text on top of it in white, precompose it, then use it as a displacement map on the wall layer, and keyframe the displacement to have it “push” through.
Another option is to duplicate the wall, then use the text as a track matte for the duplicated layer, precompose it, and apply the bevel alpha effect to the precomp. You can then keyframe the depth of the bevel to have it “push” through.
None of these methods will look stunning, but like I said, to have it look like the way you are imagining, it should be done in a 3D application.
Jon Geddes
Motion Graphics Designer
http://www.precomposed.com -
Richie Soto
March 22, 2009 at 3:53 amOk—thanks for such detail….
What 3D app would you recommend?I’ve always edited in Final Cut for the last couple of years so I’m trying expand to some more sophisticated programs.
Thanks again.
Riche
Richie Soto
March 22, 2009 at 4:07 amHey thanks for the questions.
Actually no story board just see it in my head.
The Wall is actually a metal Door with Brick around it.
But i want the TEXT to ‘push’ thru the door — so the TEXT will not completely go thru—the effect would be an imprint in the door of the TEXT.This will happen after the end of a sequence–the TEXT does not need
to move in 3 dimensions (although that is a good idea).TEXT should move all at once.
Thanks for your response
Richie. -
Richie Soto
March 22, 2009 at 4:12 amOh yeah — So the TEXT WOULD EXTRUDE thru something presently occupying the place.
THANKS AGAIN
Richie
