Activity › Forums › Adobe After Effects › Making Text Smoke Thicker
Posted by Lewisd on April 17, 2006 at 10:28 pmI am using displacement and blur to cause my words to apper like somke when they leave the screen. What setting do I need to change to make the smoke appear thicker, almost cloud-like.
Ryan Hill replied 20 years, 4 months ago 3 Members · 6 Replies -
Lewisd
April 18, 2006 at 9:49 pmThanks for the advice. One question, i’m not sure what you mean by “choker”
John Dickinson
April 19, 2006 at 1:20 am -
Ryan Hill
April 19, 2006 at 5:31 amYes. It’s intended for keying, you can remove pixels from around the edge of something. But if you use a negative value, you can expand something. With a text layer I can’t say for sure if the added border will be the same colour as your text. If not, you can always make the text layer a track matte of a layer that’s the colour you want.
Lewisd
April 19, 2006 at 11:55 amThanks,
Also what is the best way to also have a smokey background so that it looks like the text is coming from inside the smoke. I tried to do the fractal noise, but that looks too fake.
Ryan Hill
April 19, 2006 at 9:25 pmI’d be tempted to shoot some footage of smoke with a camera.
But if you want a computer solution, the “simulation” effects such as particle playground can add a level of realism you wouldn’t get with just fractal noise. Possibly foam or particle playground or one of the other particle effects could do it, but learning how to use them properly can be a lot of work.
I’ve done some smoke with particle playground, but that was just a thin stream.
Maybe this:
https://www.creativecow.net/articles/eriksson_emanuel/sand/index.htmlCould be changed to help provide a bunch of wispy smoke. If you want thick smoke, put some of the fractal noise in the background.
