Activity › Forums › Adobe After Effects › making text bounce
making text bounce
Posted by Anonymous on September 22, 2007 at 11:50 pmum…I need help with making text bounce like a ball.
Alex Werlan replied 18 years, 2 months ago 6 Members · 5 Replies -
Darby Edelen
September 23, 2007 at 12:44 amBalls can bounce in many different ways… what did you have in mind exactly?
Darby Edelen
DVD Menu Artist
Left Coast Digital
Aptos, CA -
Tazer
September 23, 2007 at 11:58 amYou can just animate the position, but there are many different ways to make it bounce, what kind of bounce are you looking for?
Steve Roberts
September 23, 2007 at 2:05 pmUsually this is done by hand, by tweaking the position curves. You squash the ball by tweaking the scale curves, and possibly moving the anchor point to the bottom of the ball.
It’s a rite of passage for an animator. 🙂
I think they touch on it in the Help…? Otherwise, you could search for a tutorial using “after effects”, “squash” and “stretch”.
Anybody else?
Mike Clasby
September 23, 2007 at 8:05 pmI found the no-creeping version for when you have an initial x velocity (thanks to the cow for tuning up the Search engine). If you change the last line of Dan’s to this:
[position[0] + Vx0*(-Math.pow(2,-time) +1), floor – y]
Then you put the second line to have an initial x velocity, like this:
Vx0 = 300; // initial x velocity (pixels/second)
And you text is positioned at the top left of the screen, or just off-screen left, then you will get text that flies in from the left and bounces, skidding to a stop. Change the first line to give it y velocity makes it jump up and left before bouncing.
Anyway the whole expression might look like this:
For Position:
Vy0 = 800; //initial y velocity (pixels/second)
Vx0 = 450; // initial x velocity (pixels/second)
g = 2500; // gravity (pixels/second/second)
floor = 400;
e = .85; //elasticityb = floor – position[1];
h = b + Vy0*Vy0/(2*g);
T = Vy0/g + Math.sqrt(2*h/g);if (time < T){ y = Vy0*time - g*time*time/2 + b; }else{ Vy = -(Vy0 - g*T); while (true){ Vy *= e; t = T; T += 2*Vy/g; if (time < T){ t = time - t; y = Vy*t - g*t*t/2; break; }else if (T - t < thisComp.frameDuration){ y = 0; break; } } } [position[0] + Vx0*(-Math.pow(2,-time) +1), floor - y] For Scale: Vy0 = 800; //initial y velocity (pixels/second) Vx0 = 450; // initial x velocity (pixels/second) g = 2500; // gravity (pixels/second/second) floor = 400; e = .85; //elasticity d = .02; //squash factor spd= 10; //speed of squash oscillation decay= 10.0; //how fast squash slows down b = floor - position.valueAtTime(0)[1]; h = b + Vy0*Vy0/(2*g); T = Vy0/g + Math.sqrt(2*h/g); if (time < T){ x = scale[0]; y = scale[1]; }else{ Vy = -(Vy0 - g*T); while (true){ max_dev = e*Vy*d; Vy *= e; t = T; T += 2*Vy/g; if (time < T){ t = time - t; x=scale[0]+max_dev*Math.cos(spd*(t))/Math.exp(decay*t); y=scale[0]*scale[1]/x; break; }else if (T - t < thisComp.frameDuration){ x = scale[0]; y = scale[1]; break; } } } [x,y] With these two expressions. if you started the text's initial position as just off-screen left, halfway up, then it will bounce on and stop in about the middle of the screen, with the floor at 400.
Alex Werlan
July 26, 2008 at 7:58 am@ yikesmikes Can you help me?
Try to make effect like here https://www.adobe.com/type/. I find bouncing text effect in AE CS3 presets (or this one expr), but it works only along Y axis (vertical direction). How I can modificate it? Or can you one help with scalebel expression for different tasks? Resume: want to make bouncing effect not from the floor only, but from the right or left wall.
