Activity Forums Apple Final Cut Pro Legacy making TC continue in part 2 of edit
  • making TC continue in part 2 of edit
    Posted by Paula Stein on July 9, 2008 at 12:23 am
    I need to break down my documentary into 2 parts for the composer.
    He is requesting part 2 time code to be continuous from part 1
    Is there a way to do this easily?
    Thanks in advance!
    Paula
    “A journey of a thousand miles must begin with a single step.” ~Lao Tzu
    Jerry Hofmann replied 18 years, 1 month ago 2 Members · 1 Reply
  • Jerry Hofmann
    July 9, 2008 at 1:20 pm
    In the second sequence’s settings (select it and type cmd+zero) you can change the sequence’s timecode to whatever you want… so just change it so it continues on… or export the first half, then export the second half using in and out points for the export.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
