Activity Forums Adobe After Effects making streamers
  • making streamers
    Posted by Craig Hellen on October 22, 2007 at 8:40 am
    Hey all,
    I am in the middle of a project and I have got to a part where I want to use a party streamer graphic to liven things up.
    I was wandering if there was a way to (preferably) animate a vector graphic created in Illustrator onto some sort of 3d motion path? Basically to make it twirl down the screen.
    If the 3d part of this isnt possible is there a way u can get Illustrator graphics to move and follow simple 2d motion paths?
    Hope you guys can help, you are all legends in my eyes!
    Kevin Camp replied 18 years, 10 months ago 2 Members · 1 Reply
  • Kevin Camp
    October 22, 2007 at 3:59 pm
    you could use cc cylinder to wrap a skinny image into a spiral (it can only wrap it once, so it won’t be a curly curl).
    to quickly test to see if this can work for you…
    1. create a new comp (typical settings)
    2. add a skinny solid (like 720×20) and rotate it diagonally, say 45 degrees
    3. drag that comp into a new comp (same settings)
    4. add cc cylinder to the nested comp layer and adjust the radius as need. if that seems like it could work for you, continue.
    5. to animate the drop, go back the first comp and animate the postion of the solid to drop from off screen top to off screen bottom
    6. go back to the second comp and animate the y rotation (in the cc cylinder properties) to rotate say 1 revolution over the same time that it takes to drop off screen.
    if you still like it, you can rework that first comp to put in a custom streamer, and coninue to tweak settings in the cylinder properties (you can adjust lighting and shading options too)
    you can also add falling confetti like pieces with a particle system like cc particle world (included in ae pro bundles) or particular (from trapcode.com).
    for particle world you could start with settings like:
    longevity: 5
    producer: pos y: -0.4; radius x: 1; radius z: 1
    Physics: animation: twirly; velocity: .1; gravity: .1; resistance: .5; extra: 5; extra angle: 3x
    Particle: type: tripoly or quadpoly (textured poly if custom); rot speed: 720; init rot: 720; max opacity: 100
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
