Activity › Forums › Apple Final Cut Pro Legacy › Making Sound Louder, and Combining Sequences
  • Making Sound Louder, and Combining Sequences
    Posted by Getagb on March 31, 2006 at 2:20 am
    Two questions, which should be easy to answer:
    1. I can turn up the sound by double-clicking on the clip in the timeline, and then adjusting in the Tool Bench. But I can only go up to +12db there, which isn’t enough on some quiet clips. How can I make the video louder than that?
    2. I’m arranging my project such that there’s a difference sequence for each scene in the film. Once I’m done, how do I arrange the sequences (that is, the scenes) in the proper order? Can I have sequences within one main sequence?
    I really appreciate your help!
    Aaron
    Tom Wolsky replied 20 years, 6 months ago 2 Members · 1 Reply
  • Tom Wolsky
    March 31, 2006 at 11:46 am
    You can double the tracks. You can select the audio and use the nets items function and then raise the level of the nest. You can also use a filter to add pregain to the level.
