Thanks Frank for that but it doesnt quite fit my needs.
This is my base equation:
Line = length(toWorld(anchorPoint), thisComp.layer(“Null 1”).transform.position);
delta = toWorld(anchorPoint) – thisComp.layer(“Null 1”).toWorld([0,0,0]);
radiansToDegrees(Math.atan2(delta[0],-delta[1]))
But i need it to react so that the further away it is from the X and Y axis the more accurate the direction of line is. And vice versa.
So i extended it to this:
YNull = length(toWorld(anchorPoint), thisComp.layer(“Null 1”).transform.yPosition);
XNull = length(toWorld(anchorPoint), thisComp.layer(“Null 1”).transform.xPosition);
radiansToDegrees(Math.atan2(delta[0],-delta[1]))*(Math.atan2(ease(YNull,740,850,3,1), ease(XNull,390,500,3,1)))
But now it will not follow my Null layer correctly. I will attach a picture below of both expressions results.
You may notice a grey opacity and that is where the lines should be to fit the design.
BASE EXPRESSION:
EXTENDED:
