Activity › Forums › Maxon Cinema 4D › Making Selected Mograph clones disappear
  • Making Selected Mograph clones disappear
    Posted by Anders Hattne on June 17, 2011 at 12:23 pm
    I’ve got a bunch of spheres distributed on a floor. (With dynamics, they are about 800..)
    I want some of them to dissapear, at one point. What I have done is ad four spheres in a cloner grid formation. Third sphere in the cloner has a visibility tag and i turn opacity to 0. I was hoping a step efector could get them to disappear a bit more randomly. But that didn’t happen.
    Now I’m thinking some effector with a fall off would be much better. But what could I use to make them disappear?
    Many thanks,
    Anders
    http://www.ardillamedia.com
    Anders Hattne replied 15 years, 3 months ago 3 Members · 3 Replies
  • Greg Burrus
    June 17, 2011 at 1:08 pm
    I have figured out two way you can get this effect. The idea behind is it you have 3 object in a cloner with is set to sort mode for clones. Inside the cloner you have your copies of your objects each with either a display tag or texture that has the visibility or transparency from 100 to 0. Each should have a different value and it seems to more you have the better the transition. Then you add a effector, I used a step, and set it to modify clones at 100%. Then I added a fall off and ran it through the clones. I’m sure you have to play with it a bit to get the effect you want but this should give you the idea.
    I’ve uploaded my testing file as an example. Hope this helps.
    Greg
    2458_disappearclones.c4d.zip
  • Adam Trachtenberg
    June 17, 2011 at 2:35 pm
    A simple way to do it is to use a Random Effector with the visibility box checked (paramters tab) . Then set the mode (effector tab) to noise and adjust the speed, scale, and Min/Max values.
  • Anders Hattne
    June 20, 2011 at 8:56 am
    Hi, thank you very much for your suggestions. Both seem to do the trick perfectly!
    Anders
