Making SD DVD
Hello!
Sorry If I’m repeating some often asked questions…
I have a huge ProRes video 1355×720 24p which is 56 minutes long. It has a very slow motions there and constantly repeating movements (theatrical performance). I need to compress it and record it to SD DVD.I have seen some posts here saying that BitVice should be used, but I have and will have only Apple Compressor, MPEG StreamClip (which cannot make mpeg2 I assume) Adobe Encore or DVD Studio Pro in my workflow.
The most stupid question of mine is about PAL and NTSC. Is it still a problem for modern players (I’m in Europe)? I would love not to sacrifice the motion reproduction of 23.98 fps, is it true to be possible with NTSC, only NTSC?
If I understand the workflow correctly:
1) downscale it in MPEG Streamclip? 720×383? Save in the same codec? I am having a double loss here?
2) Import to compressor? There I should stick to manual settings of mpeg-2?
If yes, once again about PAL/NTSC. If NTSC Shall I select 23.98? 16:9 Progressive?
For that type of slow moving footage shall I use Two Pass VBR Best?
What settings for av. bitrate an maximum? Motion estimation? Shall I change the GOP structure from IBBP 15 to smth else? Maybe some other settings? Workflows?
3) shall be just importing the m2v file DVDSP and burning?Thanks in forward!
Kirill
