Activity Forums Maxon Cinema 4D Making Rounded Side from Flat Surface
  • Making Rounded Side from Flat Surface
    Posted by Jim Zito on June 14, 2013 at 8:45 pm
    Hello,
    I think the pics illustrate what I want to do better than I can explain it. I want to extrude the flame in a way that makes it rounded, not just give it depth.
    Jim
    Dan Conrad replied 13 years, 3 months ago 3 Members · 2 Replies
  • Cassius Marques
    June 14, 2013 at 9:21 pm
    In the caps tab of the extrude nurbs: Change it to fillet caps, add some steps and then try to put that inside a hyper nurbs. You may have to add vertices to the base spline to keep the corners in place. But to make exaclty like the photo you may have to model it that way.
  • Dan Conrad
    June 18, 2013 at 12:53 am
    Try modeling it with a spline and Lathe Nurbs.
    http://www.mographcandy.com
    Twitter: @mographcandy
