Activity › Forums › Apple Final Cut Pro Legacy › Making regular video look like stop motion
Posted by Shea Scott on April 26, 2010 at 9:06 pmHey does anyone know how to make regular video look like it is really stop motion. Here is an example:
https://www.youtube.com/user/MysteryGuitarMan#p/c/CF81022FAB19616C/3/XCWkyjdt5wc
How does he make his movements look stop motion?
I am using final cut so if anyone knows how to do it there?
Mark Hunt replied 14 years, 8 months ago 5 Members · 7 Replies -
Dan Rollins
April 27, 2010 at 9:07 amYour example is not playing for me? Can you check your link.
Cheers,
Dan Rollins
HDSLR Videographer (T2i & 7D shooter) – FCP7.0.2 (Studio 3) – 27″ iMac 2.8 Quad Core i7 4GB RAM – ATI Radeon HD 4850 -
Matt Callac
April 27, 2010 at 2:41 pmYour example didn’t work.
if you have After Effects there is a posterize time filter. Dropping the framerate down to 12 or even lower might achieve the look you are trying to get. Alternately motion has a strobe filter that you may be able to achieve a similar look with.
-mattyc -
Matt Callac
April 27, 2010 at 2:49 pmJust noticed that the same strobe filter is available in fcp as well.
-mattyc -
Shea Scott
April 27, 2010 at 7:45 pmhttps://www.youtube.com/user/mysteryguitarman?blend=2&ob=4#p/c/CF81022FAB19616C/4/XCWkyjdt5wc
sorry here is the link. I found the strope effect in Final cut and it looks decent but I think I’ll try messing with the frame rate and see if i can get it smoother. Any tips on how to do that in FC. Do I have to change the frame rate of my whole time line?
Shea
Matt Callac
April 27, 2010 at 11:05 pmyeah that link still isn’t working….you shouldn’t need to mess with the framerate of your timeline. Just mess with the parameters of the strobe effect.
-mattyc
Chris Wiggles
May 13, 2011 at 7:18 pmI was just searching for the answer to this question myself and discovered that the Strobe filter does a pretty good job of basically just making your video a slow frame-rate. If you actually want to make it realistically like stop-motion, then that would take more effort. I was just going for a look of basically a series of still frames, and didn’t want to make them all manually. the strobe filter does exactly that, simple!
Hope that helps someone else. 🙂
Regards,
Chris -
Mark Hunt
January 8, 2012 at 9:37 pmQHQ Stop motion is a script for after effects which works a treat!
