Activity Forums Apple Final Cut Pro Legacy Making projects mobile
  • Making projects mobile
    Posted by Zach Marion on October 28, 2007 at 5:21 am
    All of my projects share the same scratch disk. Is there an easy way to export a project to transfer to another machine without having to pick through the ‘Final Cut Pro Documents’ directory? Or, should I be setting the scratch disk to a separate ‘Final Cut Pro Documents’ folder every time I start a new project?
    Alan Lacey replied 18 years, 10 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    October 28, 2007 at 12:45 pm
    When you work with scratch disks, select just the drive itself in the scratch disk settings. FCP will take care of all housekeeping all by itself… putting renders, captures all in folders named the same as your project file they belong to.
    If you want to move the media to a new location, use media manager to do this. Make copies, create a new project file (in media manager), select a location for the media, and then click OK… check the new project file and it’s copied media before you trash the originals… that’s all there is to it.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Alan Lacey
    October 28, 2007 at 1:15 pm
    that’s what I do Marionza.
    I have an FCS project template which I duplicate for each project. One of the folders in it I call FCP files and set that for the scratch.
    Works well for me
    Alan
