Activity Forums Adobe After Effects making particular’s emitter follow a mask path??
  • making particular’s emitter follow a mask path??
    Posted by Pouyan Fard on April 12, 2008 at 4:49 pm
    Hello
    I am trying to make Trapcode Particulars Emitter to go along a mask path that I have drawn by hand with the pen tool. Is there an easy way to tell the particular emitter to just follow the mask path.
    Any help would be great
    Thanks in advance
    Pouyan
    Darby Edelen replied 18 years, 1 month ago 3 Members · 2 Replies
  • Mark Crenshaw
    April 13, 2008 at 8:36 pm
    I did this just yesterday…The following worked for me. Hope this is what you are wanting to do.
    1. On the layer that holds your mask, Hit M for mask, twirl it down and select the “Mask Shape” parameter. Crtl+C on Win, or Cmd+C on Mac. This copies the mask vertices…you should see them all selected in the comp window.
    2. Go to the layer that has the Particular plugin assigned and twirl down the effect into the “Emitter” and select the “Position XY” parameter. Ctrl+V on Win, or Cmd+V on Mac. This will paste the vertices’ positions as keyframes. All of the keyframes between the first and last will show as “roving” keyframes…if you want to change any one of them just right click it and turn off “Rove Across Time”
  • Darby Edelen
    April 15, 2008 at 7:29 am
    In the future you should consider creating a motion path for a Particular emitter instead of a mask. Masks are limited to 2 dimensions (X,Y) while a motion path on a 3D layer can move in 3 dimensions.
    Consider creating a 3D Null layer and animating it in 3 dimensions. You can use the same pen tool to adjust the motion path once you’ve created it, the only difference being that you can adjust it in 3 dimensions. You then need to link the position of the emitter to the position of the Null with expressions.
    An alternative is using a light as an emitter for particular, which requires no expressions to link the position.
    Darby Edelen
    Lead Designer
    Left Coast Digital
    Santa Cruz, CA
