Activity Forums Adobe After Effects Making Particular Follow a Null Whilst Rotating
  • Making Particular Follow a Null Whilst Rotating
    Posted by Simon Dayton on May 8, 2012 at 4:10 am
    OK, I’m tearing my hair out here on what is most probably the simplest technique.
    It’s basically this:
    I create a comp 500×500
    Then create a NULL which automatically centres.
    I move the anchor point and then create a solid and place in Particular.
    What I’m trying to achieve is making the Position X,Y of the Particles FOLLOW the NULL’s position. However if I try to rotate the NULL, it goes around the Anchor point fine but the position doesn’t change. Therefore if I parent the Position X,Y of particular, it doesn’t move as it’s still seeing the original (and static) Position point of the NULL.
    How can I make Particular follow a NULL whilst rotating it in a circle, rather like light streaks captured when someone does a circular motion with a firework sparkler in the dark if you see what I mean.
    Phew.
    Thanks in advance for any advice.
    Roland R. kahlenberg replied 14 years, 3 months ago 4 Members · 4 Replies
  • Andy Copeland
    May 8, 2012 at 5:04 am
    I think I understand the question…
    Try making the Particular with a Light Emitter, parent the Light to a 3D Null in the centre of the comp, then just rotate the Null on the Z-axis. A lot easier than trying to do it with expressions.
  • Dan Fredley
    May 8, 2012 at 6:15 am
    I’m not sure I completely understand, but you can just use a light called “Emitter” that is parented to a rotating null. There are more complicated ways using expressions.
    Dan Fredley
  • Simon Dayton
    May 8, 2012 at 7:10 am
    Yup, I managed to figure the problem out as you mentioned by using an emitter..Now it’s working fine. 🙂
    Thanks for the help, much appreciated.
  • Roland R. kahlenberg
    May 8, 2012 at 8:11 am
    A Particular Layer is inherently a 2D layer BUT it works within a 3D space which is essentially within its own 3D space. Parenting a Particular Layer to another layer will inadvertently lead to undesired results.
    To link a Particular Layer to an AE Layer, your best option is to use a Light Layer – as others have opined in this thread.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
