Activity Forums Adobe After Effects Making particles fly by?
  • Making particles fly by?
    Posted by Nick Army on November 20, 2008 at 3:46 pm
    This should be pretty simple, but I’m not sure. What I’d like to do is basically make it look like particles are rushing past the camera (although I don’t think I actually need to make a camera for this), kind of like driving through snow or flying through space – I might use words or symbols though. Anyway, how would I achieve this best?
    Right now I’m using Particular with a point emitter/direction: outwards/250 velocity/opacity 0-100 over life span so it looks like they’re coming from a distance. However, I’ve seen videos where it looks much better – instead of going outward like this, particles look to really be moving through Z-Space. Do I need a box emitter instead? Any help would be great. It seems like this is a pretty easy thing, I just can’t seem to see where I need to look. Thanks!
    David Bogie replied 17 years, 10 months ago 3 Members · 3 Replies
  • Nick Army
    November 20, 2008 at 3:51 pm
    Well, using a box with an Emitter Size z – 500, x – 100, y – 100 seems to help a lot. Looks like I want it to mostly, but I’m still wondering if there is a better or more realistic way I’m overlooking.
  • Bill Kelly
    November 20, 2008 at 5:09 pm
    Add a camera into your comp and keyframe the z position at the beginning, move ahead in the timeline, and move your camera forward on the z axis until you see its position having the particles move past.
    For example, at the beginning your z position is at -1867 (I think) if you use the 35mm preset on the camera. Keyframe that position at the beginning of the comp, move forward a couple seconds in the timeline and change the z position to 0. You’ll see you moved forward. Adjust as needed. Good luck!
  • David Bogie
    November 20, 2008 at 5:57 pm
    Drop by the Cycore site and download their particle world demonstration files. You will find exactly what you are asking about, flying through a stream of particles. it’s cool. No, you don’t need a camera but you will manipulate the camera that is in the Particle World system.
    bogiesan
