Activity Forums Apple Final Cut Pro Legacy Making my HD project look good in SD
  • Making my HD project look good in SD
    Posted by Joseph Wilkins on November 2, 2006 at 4:24 pm
    So I have a HVX200 and have shot a TV spot for a client – first one using the HD format.
    I want to put it out to a SD DVD so the client can show it at a conference on a big screen TV.
    How do I get the best possible quality?
    The footage is in a 960 x 720 format at 23.98 fps
    I exported the file from FCP as a QT movie, then brought it into a NTSC DV comp that is 29.97 fps
    It looks choppy and pixelated.
    Please help
    David Heidelberger replied 19 years, 11 months ago 2 Members · 3 Replies
  • David Heidelberger
    November 2, 2006 at 5:32 pm
    The DVD spec supports 23.98 video. If you bring your Quicktime movie into Compressor and choose, say, the DVD: Best Quality 90 Minutes 16:9 preset, that should give you good results. Or, really, you can use any preset you want, just make sure that “Rate” is set to 23.98 and “Aspect Ratio” is 16:9.
    – David
  • Joseph Wilkins
    November 2, 2006 at 6:11 pm
    so I should bring my HD footage or SD footage into Compressor?
    November 2, 2006 at 6:40 pm
    I would bring in the HD footage. You already have a rendered version, why make more work for yourself? Let Compressor handle the downconversion.
