Activity Forums Apple Final Cut Pro Legacy Making Multiple Timelines out of Multiple Clips
  • Making Multiple Timelines out of Multiple Clips
    Posted by Adrian Salinas on January 24, 2010 at 9:59 am
    I want to make multiple timelines out of multiple clips each on its own timeline,
    I would like to know If there is a way to do this without having to do it manually one at a time.
    I would greatly appreciate any help.
    Adrian
    Jerry Hofmann replied 16 years, 7 months ago 2 Members · 7 Replies
  • 7 Replies
  • Jerry Hofmann
    January 24, 2010 at 3:17 pm
    You can duplicate sequences in the Browser by typing cmd+d if that’s what you’re asking.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Adrian Salinas
    January 24, 2010 at 8:42 pm
    Hi jerry thanks fro taking the time to respond my question, but sadly its not that simple, what I want to do is find a way were i can take a bin full of clips and some how make a timeline for every clip without having to do it one by one.
    thanks anyway
  • Jerry Hofmann
    January 25, 2010 at 12:39 am
    I didn’t quite understand what you wanted to do. Why are you needing to do this?
    Jerry
  • Adrian Salinas
    January 25, 2010 at 12:56 am
    I am making stock clips out of lots of different footage shoot over time, I need to trim and color correct all of it and some times edit stuff out, cut the sound, etc.
    I want to do this by having 1 time line per clip so at the end i can batch export.
    the way im doing it now is making each timeline one by one, this is very time consuming
    i would like to know it i can batch or automate this action so all the clips inside a folder go each to its own separate timeline,
    thanks for the help i appreciate it
  • Jerry Hofmann
    January 25, 2010 at 5:16 am
    You have sort of a unique problem all right… have to have clips in a sequence to send them to Color alright…
    Only thing I can think of to improve a one at a time method is to put many in a single sequence, then pull the edited and corrected clips from that sequence to a browser after it’s sent back from Color maybe?
    Jerry
  • Adrian Salinas
    January 26, 2010 at 1:28 am
    Hey Jerry I found something that might work, It looks really promesing for all this batching tasks
    https://www.xmedit.com/ its called traffic, check it out
    thanks for the help
    A
  • Jerry Hofmann
    January 26, 2010 at 1:30 am
    Ya know? I’d forgotten about this software! It may well be the ticket you’re looking for indeed! It does as advertised, at least used to…
    Jerry
