Activity › Forums › Apple Final Cut Pro Legacy › Making .MTS files compatible with FCP
  • Making .MTS files compatible with FCP
    Posted by Charlie Johnson on December 6, 2011 at 4:49 pm
    Anyone know the proper conversion parameters for .MTS files in HD shot out of a Sony Handycam AVCHD to be converted into .mov files or some format compatible with FCP? Every time I attempt the conversion either there is an aspect ratio issue or the audio gets out of sync. I’m using Aiseeoft HD Converter, but would be willing to buy something else if it could give me a quick and easy alternative. Thanks.
    Boatguy
    Gary Milligan replied 14 years, 10 months ago 4 Members · 6 Replies
  • Gary Milligan
    December 6, 2011 at 6:04 pm
    Give ClipWrap a try. They have a trial version.
    https://www.divergentmedia.com/clipwrap
    HTH
    This is me – this is what I do – https://web.mac.com/garymmw
  • Charlie Johnson
    December 6, 2011 at 7:00 pm
    Thanks. I’ll give it a try. If you can’t already tell, I’m a neophyte when it comes to all this. Aiseesoft would probably work fine, I just don’t know what conversion parameters to use.
    Encoder ?(audio and video)
    Bitrate ? (audio and video)
    Frame Rate ?(video)
    Sample rate ?(audio)
    Boatguy
  • Norm Legge
    December 7, 2011 at 3:25 am
    If you still have the source media card with its file folder structure intact you can go directly to final cut with Log and Transfer.
    https://library.creativecow.net/articles/ross_shane/tapeless-workflow_fcp-7/video-tutorial
  • Rafael Amador
    December 7, 2011 at 4:46 pm
    READ THAT TUTORIAL, and if for any reason you can’t go through L&T fallow Gary advise and give a try to ClipWrap. Depending of the kind of “.MTS” you may don’t even need to convert the files, but just re-wrap and import to FC. Faster and you don’t need to care about conversion settings. I think they have a free-trial.
    Doesn’t rewrap every kind of MTS. My had to convert my old JVC files.
    rafael
    http://www.nagavideo.com
  • Charlie Johnson
    December 8, 2011 at 10:34 pm
    Thanks everybody. Problem solved — ClipWrap works great and is super fast!
    Boatguy
  • Gary Milligan
    December 8, 2011 at 11:19 pm
    Thanks for the update. Glad to hear you’re a happy camper!
    Gary
