Activity Forums VEGAS Pro Making masks bigger/smaller
  • Making masks bigger/smaller
    Posted by Paulina Nowak on June 22, 2008 at 10:05 pm
    Hello.
    I have the question. If I want to mask one character which doesn’t change their pose, just getting bigger or smaller is there an option I make one mask and zoom it? So I didn’t have to make lots of unnecesseary ones?
    I’m using Sony Vegas 7.0
    John Rofrano replied 18 years, 2 months ago 2 Members · 1 Reply
  • John Rofrano
    June 23, 2008 at 2:57 pm
    Create the mask on a separate track and use Pan/Crop or Track Motion to resize it accordingly. The easiest way to accomplish this would be to use the Mask tool in Pan/Crop to make the original mask over the event with the character. Then save that as a preset and remove it from the event. Now create a new event out of Solid White Generated Media on a new track above and apply the mask shape to that event. You may have to change the mask type to negative because I assume you want to create a hole. Then change the compositing mode of the upper (mask) track to Multiply (Mask). This should create a mask that you can now resize.
    ~jr
    https://www.johnrofrano.com/
