Activity Forums Adobe After Effects Making Light Disappear & Reappear Behind Objects Using Expressions
  • Making Light Disappear & Reappear Behind Objects Using Expressions
    Posted by Justin Giudici on September 21, 2007 at 3:12 pm
    I have a quick question about this tutorial. When I set the code in on the flare brightness it says an error occurs on line 2. The error reads class ‘ layer’ has no property or method named ‘sky’.
    Error occurred at line 2.
    Expression disabled.
    If you could help me out I would appreciate it.
    Justin Giudici replied 18 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
