Activity › Forums › Compression Techniques › making letterbox from 4:3 source Episode
Posted by Molly Sharp on February 26, 2007 at 6:23 pmIs there a way to take a 4:3 source and have letterboxes put on it in Episode?
MollyCharles Simonson replied 19 years, 6 months ago 2 Members · 8 Replies -
Charles Simonson
February 26, 2007 at 9:47 pmYeah, that’s pretty simple. In the resize options, just crop some from the top and bottom and then choose the “Letterbox (Pad)” option for the “Maintain Aspect Ratio by” selection.
Molly Sharp
February 26, 2007 at 10:00 pmThanks for your reply. Should I maintain the 4:3 in the size options in the upper LH corner? I am trying what you said and having zero luck. Sorry, it is probably something obvious I am missing. It is definitely cropping, but what I need are those actual black bars. My project is to update our website, and currently all videos are 16 x 9 with bars, but I need to be able to add bars to the occasional 4:3 footage I might get.
thanks again,
Molly
Charles Simonson
February 26, 2007 at 10:13 pmI just tried this before posting and it worked fine for me. Is there any way you can post a small sample of your source? Just two or three frames would be sufficient.
Molly Sharp
February 26, 2007 at 10:22 pmYes, but forgive me, new to the cow, is there some way for me to post through the Cow?
thanks,
Molly -
Charles Simonson
February 26, 2007 at 10:24 pmNo, you need to do that through your website or such.
Molly Sharp
February 26, 2007 at 10:26 pmCopy that, no website of my own, can I email it to you?
thanks,
Molly -
Molly Sharp
February 26, 2007 at 11:04 pmI think it is definitely something I am doing wrong with the actual cropping. Nothing happens when I type numbers in the top or bottom but it crops when I type in the left or right. Only then it types top to bottom.
thank you,
Molly
