Activity Forums Adobe After Effects Making layer oblivious to lighting
  • Making layer oblivious to lighting
    Posted by Ryan Hannebaum on January 15, 2014 at 6:36 pm
    I have a 3D scene with a number of lights (spot and point).
    In that scene I have one layer that I want to appear to be “glowing” on its own accord. To do that, I want it to ignore all the environment’s lights (because a glowing object creates its own light and is impervious to outside lighting).
    I’m not understanding how to do this, because when I set the layer’s Accepts Lights property to Off, the layer appears completely black. When I set it to On, it becomes shaded and affected by Light layers (which I don’t want).
    I’m sorry if this is a bit ambiguous, but I’m happy to follow up with more details if they’re needed.
    Thank you!
    Philip Bowser replied 12 years, 7 months ago 2 Members · 3 Replies
  • Philip Bowser
    January 15, 2014 at 7:10 pm
    Hmm.. Seems like there is something else going on here, because when you check a layer’s “Accepts Lights” property to off, it should show up looking how it normally would. However one thing it could be is the “Accept Shadows” property? Even though light won’t be illuminating the layer, it still has the ability to accept shadows from other layers. Perhaps there is another layer casting a shadow over this one.
    If that’s not the case, do you have any effects applied to this layer? Is it a nested comp? What are some of the details about the scene?
    Cheers,
    Philip. Bowser
  • Ryan Hannebaum
    January 15, 2014 at 7:28 pm
    You nailed it. Turned Accepts Shadows to Off and voila! Thanks, and sorry for such a stupid question. For some reason I had thought I already tried that and it didn’t work, but I was obviously mistaken.
  • Philip Bowser
    January 15, 2014 at 10:47 pm
    Great! Glad you figured it out. Definitely not stupid at all, I’ve been stumped by way simpler problems.
    Philip. Bowser
