Activity Forums Maxon Cinema 4D making holes
  • making holes
    Posted by Adam Guy on August 27, 2006 at 4:35 pm
    I have cylinder that I want to make holes in its surface. Is there an easy way of doing this? Thank you
    Adam Guy replied 20 years ago 4 Members · 8 Replies
  • 8 Replies
  • Simon Carlson-thies
    August 27, 2006 at 6:11 pm
    What kind of wholes and how many do you need?
    easy way boolean operations…
    or polygon modeling, but it all depends or your needs….
    Simon Carlson-Thies,
    Digital Light Graphics And Animation
  • Adam Guy
    August 27, 2006 at 6:23 pm
    the holes would be like you have drilled through the surface to the inside. I want to be able to shine light from inside the cylinder which then leaks out of it… cheers
    August 28, 2006 at 12:41 pm
    well boolean operation would be best….
    unless you have a lot of holes….
  • Adam Guy
    August 28, 2006 at 2:37 pm
    Thank you very much. I have found a couple of tutorials from what you suggested. Thanks again
  • Adam Guy
    August 28, 2006 at 3:13 pm
    Just thought I’d say that I have completed the tutorial and know how to do it. I am a complete beginner with C4d. thank you very much for you help. I am now less stupid!
  • Michael Munkittrick
    August 28, 2006 at 5:38 pm
    For future reference, what you asked how to do is found within the first 15 pages of your manual. There are countless different ways to “mak a hole” in something, but you really should take a look at the manual first as it will always have the correct answer when you’re just getting started in C4D.
    Good luck!
    Michael Munkittrick
    Gainesville, Florida USA
  • Davesink
    August 28, 2006 at 8:58 pm
    In addition to the manual, which doesn’t always present the clearest approach to a particular problem, this tutorial from 3D Kiwi at c4dcafe.com does a great job of explaining muliple ways of making holes.
    https://www.c4dcafe.com/ipb/index.php?automodule=downloads&showfile=113
  • Adam Guy
    August 29, 2006 at 6:33 pm
    Many thanks, very kind of you. Ill check it out.
