Activity Forums Maxon Cinema 4D Making holes in a sphere object.
  • Making holes in a sphere object.
    Posted by Greg Paterson on February 23, 2006 at 1:13 am
    Greetings,
    I need to make some nice smooth round holes on the surface of a model which is based on a sphere primative.
    I have attempted to use a boolean for this but the results are not nice …ie not a smooth clean hole.
    What is the best approach to this.?
    Greg
    Adam Trachtenberg replied 20 years, 7 months ago 3 Members · 3 Replies
  • Nolan Scott
    February 23, 2006 at 1:42 am
    Well, if you spike your sphere with a few cylinders in your choosen size –
    maybe group the cylinders in a null and increase the segments in the sphere
    maybe to 48 – put them all in a Boole-Object (the sphere in first position) –
    either A subtract B or A without B.
    I find the holes look very
  • Greg Paterson
    February 23, 2006 at 3:12 am
    Thanks Nolan,
    Yes, probably not enough cylinder segments in my first attaempt.
    Cheers
    Greg
  • Adam Trachtenberg
    February 23, 2006 at 4:12 pm
    Another approach is to use a bitmap in the alpha channel–if the sphere doesn’t have thickness.
