Activity Forums Adobe After Effects Making Groups in Effects Bar for Custom Expression Controls
  • Making Groups in Effects Bar for Custom Expression Controls
    Posted by Liam Campbell on February 8, 2018 at 5:50 pm
    Is there a way to title and separate different expression controllers on one layer? Like have a “Color” Section with all of the color controllers below it?
    Arthur Hakhverdian replied 7 years, 11 months ago 3 Members · 3 Replies
  • Liam Campbell
    February 8, 2018 at 7:11 pm
    I’m assuming that that is sarcasm and that there is no way to do that? I could’ve sworn that whenever I install 3rd party plugins they are able to divide the UI or is that a custom made UI for the plugin?
  • Walter Soyka
    February 8, 2018 at 7:38 pm
    You can. This is called a “pseudo effect.” Unfortunately, the process is not very straightforward.
    This script makes it easier:
    https://aescripts.com/pseudo-effect-maker/
    But note that even with that script, there’s a somewhat laborious installation process for pseudo effects:
    https://www.batchframe.com/learn/pseudo-help.html
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Arthur Hakhverdian
    September 21, 2018 at 8:22 pm
    ‘Sup, fellas?
    That was informative, Walter. Thanks.
    Still, I’m curious as to how it works in terms of compatibility. Is a project file containing a layer utilizing a Pseudo Effect universally transferable without requiring installation of additional components? In other words, would that Pseudo Effect instance show as missing on a different machine?
    You see, my arrival at this thread was catalyzed by an Ae file with a piece of animation generated using Animation Composer (I assume you’ve heard of it). Interestingly, despite me not having the generator plugin/extension itself installed on my unit, the Pseudo Effect expression control group still shows. I had no idea you could do that. My understanding was that you were limited to just stacking the built-in expression controls from the menu.
    Illuminate, please.
    Thanks.
