Activity Forums Lighting Design Making fluorecent lights flicker
  • Making fluorecent lights flicker
    Posted by John Shand on December 2, 2012 at 4:26 pm
    Hi All, how could you make fluorecent lights Flickr on purpose. We want to create a sense of danger. Turning them off and on doesn’t make them flicker quick enough. Any info would be really appreciated.
    Dennis Size replied 13 years, 9 months ago 4 Members · 6 Replies
  • John Sharaf
    December 2, 2012 at 4:45 pm
    John,
    Although the flicker might be too rhythmic for your taste, you could adjust the shutter to introduce flicker; perhaps if your camera has the capability to dynamically adjust the shutter speed while rolling you could make a creative effect.
    JS
  • John Shand
    December 2, 2012 at 11:45 pm
    Thanks for you reply John, yes it would have to be more realistic, like when a flo light is faulty.
  • Mark Suszko
    December 4, 2012 at 8:32 pm
    I keep a set of nearly-dead tubes for this, that’s REALISM!.
    You can also derange a perfectly good flo light by introducing a magnet along the length of the tube. An electromagnet with variable power gives you more control over the effect. This is a case of trial and error experimentation.
  • John Shand
    December 6, 2012 at 1:25 pm
    Perfect! The electro magnet is the one. But from now often I’m going to start collecting old flo lights. I wonder what offices do with them, hopefully they don’t get thrown away.
  • Mark Suszko
    December 6, 2012 at 10:26 pm
    Sometimes its the ballast and not the tube that dies, and there are pro setups for monkeying with the ballast.
  • Dennis Size
    December 7, 2012 at 6:35 am
    You could also introduce a dimmer into the mix. Dimming down non-dimmable fluorscent tubes will often cause them to flicker erratically.
    Another alternative is to use the new LED source “fluroescent” fixture tubes. They might offer more of a controllable effect.
    DS
