Activity › Forums › Apple Motion › Making FCPX template that Adapts to text amount
  • Making FCPX template that Adapts to text amount
    Posted by Wesley Kelemen on August 9, 2016 at 9:42 am
    I already have a “template” or text effect I use for final cut but it really doesn’t save me enough time.
    I have white text with black rectangular boxes behind each line. Similar to those facebook videos you seen or captions in general I guess.
    Is there a way to make the black background to adjust itself to the amount of text I put on each line. So If I write 3 separate lines at different lengths the 3 black boxes automatically fit the length of the line.
    Thanks guys for any help
    Wesley Kelemen replied 10 years, 1 month ago 3 Members · 4 Replies
  • Simon Ubsdell
    August 9, 2016 at 10:44 am
    Here’s a Title effect that does pretty much exactly what you are describing.
    10400_tkysubtitler3.2.zip
    It uses a Clone of the text layer to which is added a Simple Border filter which fills out the area behind the text.
    For more than one line you’d need to use more than one instance or rework the effect as necessary.
    Hope that helps.
    Simon Ubsdell
    tokyo productions
    hawaiki
  • Robin S. kurz
    August 10, 2016 at 8:12 am
    And if you want to simply make the exact same thing yourself…
    https://www.youtube.com/watch?v=_xq61fhdW4U
    – RK
    ____________________________________________________
    Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
  • Simon Ubsdell
    August 10, 2016 at 9:48 am
    FWIW my version has a technique for creating rounded corners which is quite interesting if that’s something you like.
    Simon Ubsdell
    tokyo productions
    hawaiki
  • Wesley Kelemen
    August 10, 2016 at 10:11 am
    Very nice. Thank you.
